Old-Biscuit
Jun 12, 2014Explorer III
Norcold N300 Series fridge
Propane source valved in service
Turn thermostat to highest setting (5)
Turn selector switch to propane
Push/hold in the safety valve button while pushing the igniter button rapidly
When a flame is present and the flame meter moves into the 'green' area release the gas safety valve (do not hold safety valve in for more than 30 seconds if flame doesn't light.....start over)
Turn thermostat to desired setting
The flame meter is electrical......it senses thermocouple. AS thermocouple heats it moves meter from 'white' until thermocouple is hot and then meter reads 'green'
Check the wiring to/from meter connections
And check the flame condition when on position 5 (highest setting)
It should be strong/steady shape with dark blue inner & light blue outer flame
If NOT...clean burner area/clean thermocouple/clean burner gas orifice
