amyj72177's avatar
amyj72177
Flooring
Does it make much difference on what kind of flooring I do? I want a dark/black wood flooring, but want to keep the weight down. Does it add much weight if I used regular wood planks?
  • Just did mine. Allure vinyl plank from Ho D. Make sure it floats. Do not screwed or bolt anything though the vinyl into the subfloor.
    Prep work. Note the cutouts for the TV cabinet and co-pilot seat.
    Finished project, waiting for the couch.
  • Look up vinyl plank flooring. Lightweight and will not be hurt by moisture.
  • It will add weight. You don't want solid plank. A multiply flooring will climately hold up better as it has structual stability.
    Personally a mid tone will take less maintenance than a dark tone.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
