CharlesinGA
Feb 19, 2021Explorer
BobsYourUncle wrote:CharlesinGA wrote:Well Charles, chances are you will never have to worry about it. Not sure how cold it gets in Atlanta, but nothing like in the frozen north!!
So how cold does it have to get to for it to freeze and needing this done? Never read of this before. Inquiring minds want to know.
Charles
When I had the issues with mine, I was FT in my 3 season TT.
Temperatures dropped into the minus 30's C for an extended time. I was blowing through a 30 pounder every 2-3 days just trying to stay warm. When the temperatures got into the minus 30s, propane flow slows down and I had to put a heating pad in there with my bottles. Before I did that my furnace ceased to function. No gas, no heat. Then the fridge quit at about minus 33 or so. I bought a 110V bar fridge to use until spring.
When I was running constantly between minus 25 to -30, it wasn't a problem. Get over -30 C and things start to slow down. After I took my fridge for an end over end walk and revived it, I put a 100W light bulb in the back of it to warm it a bit. It worked. Got that idea from Don in Regina. (Pianotuna) Thanks Don.
Now ask me about frozen pipes.... That's another story.
Well I have a heated shop that the trailer would normally belong in, but I got this other one I need to get motivated on and finish replacing rotted wood and get it together and sold, It is a decent trailer otherwise, and I replaced the roof, but it is in the shop as it is opened up, and cannot go outside. The GOOD trailer is sitting under a cover outside (isn't that how it always works?).
The coldest I have ever seen here where I am now (since '94) is zero. Of course that was the day my heat pump's outside fan motor decided to take a trip south. I had to replace the blower motor outside with a torpedo heater blowing on me. The heat pump was actually producing at that temp as the house temp was being maintained (with the assistance of the back up elements) but with only the back up elements the house was slowly cooling off.
Yes, blocking off vents and installing a 100 watt light bulb (I have a couple of packs of them stashed away) would probably do the trick.
Charles
