TundraTower
Oct 26, 2014Explorer
Frame spacer vs. electric stabilizer replacement?
I have an early model 2014 Forest River Cherokee 264L equipped with the Lippert “Electric Rear Stabilizer” jacks on front and back. I bent one of the legs on the front and ordered a replacement from Ultra-Fab thru E-trailer. (Ultra-Fab buys these from Lippert and resells them for lower mark-up, I saved $200).
The units on my travel trailer have a 2” spacer between the stabilizer and the frame. This is needed on the front because the stabilizer mount straddles a ½” gas line (that’s right) coming out under the frame for accessory connections. The rear has no such obstructions but still has the 2” spacers as well. Lippert sells these units with the 2” spacer welded on the assembly under a unique part number. The Ultra-Fab unit I bought does not have the spacer.
I can fabricate the spacer out of 2” thin-wall square tubing easy enough, but being inherently lazy I’m thinking about moving my rear stabilizer with the spacers to the front, and installing the new unit on the back without the spacers.
Anyone have experience or thoughts on having one stabilizer with the 2” spacer and one without? More extension means more resistance to bending on the legs, so if by chance this Ultra-Fab unit is lighter duty that would help that.
Am I missing something?
