afidel wrote:
dougrainer wrote:
bikendan wrote:
As far as I know, RV manufacturers don't make control boards!:h
They also don't make the appliances. Kind of like blaming your Home Builder/Contractor for the HVAC system problems. Doug
Exactly, contractor grade, aka **** shoveled out at the lowest price possible meant to last just long enough for the warranty to have not expired. I blame the RV manufacturers because they've squeezed the suppliers to the point where every possible corner is cut, apparently including making a 4 function board that can crash.
You must be a control board expert. I am not. It seems reasonable there would be a reset to me.
If you’re going to keep bitsching, it would help me and others if you explained to by you think this is unacceptable and how the control panel should be constructed.
That is if you’re not just miffed they you had to reset a switch in your hidey hole. Did I read that right, you spend your days in your camper in your driveway? Why is that?
