dougrainer
Oct 24, 2019Nomad
The freezer if NOT below 10 degrees wired direct to 120 for 24 hours---------------------------BAD COOLING UNIT. Regardless of it being repaired. It was either not repaired correctly(Blockage tube removed and new one welded in place), or not charged correctly. There is no difference between the size of an RV refer and the capacity for cooling as long as operational items are correct. Doug
OR the cooling unit was not reinstalled correctly with adequate Thermal Mastic and the CU sealed to the box correctly. One item that will cause replacement problems in untrained hands is lack of enough Thermal Mastic. You CANNOT use too much Thermal Mastic when installing a cooling unit. Thermal Mastic is what promotes the removal of Heat.
