Scovndrel
Oct 24, 2019Explorer
I put about 3/8" bead of thermal mastic all along the cooling tubes and kinda poked it against the tube so it would stick there a little better. I used about 40% of the mastic cylinder on about 3 feet of tubing. Knew I should have taken a photo of how much I used.
I suppose I could remove it from the cabinet again and reinstall with a fresh tube of the stuff and put two huge beads next to each other completely covering the tubes.
I used some of the can of Great Stuff Window & Door that they included, put about a 1/2" bead (which began expanding right away) of foam around the fridge cavity before setting the cooling unit in place and adding the metal tape around the edges.
I'll check again after it's been wired direct for 24 hours. That will be about 10am PST tomorrow.
