BFL13
Nov 12, 2018Explorer II
Fresh water tank fell part way down on the 5er we had when it was still new.
The two L beams going across that hold it up --one is fixed and the other is bolted. Ours had the bolted one too far away from the fixed one so the tank was just barely on there and it slipped down at that end.
I was able to get enough of the underbelly out of the way to see and get at the ends to move the bolted L beam up snug to the tank. I inserted several washers on the bolts at each end that hold it to brackets on the frame. That got the tank sitting on the full ledge of the L.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
