Just found out the hard way, that the 1991 2-Way fridge we have (Servel brand) when switched to electric still shows the lamp even when the 120v not on. The lamp is 12v of course.
So we thought it was working ok even though the 120v had been lost, until it was opened and found to be not cold inside.
I don't know if that is normal for these fridges, even the new ones. The 2003 Norcold we had in the 5er had a "code" showing if you lost 120v to the fridge, which is what you want as a warning.
So if you have a fridge that does not show codes, be worth checking to see if that could happen to you. If so, maybe have to invent your own alarm, like a 120v lamp in the same circuit as the fridge 120v receptacle's.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
