โOct-09-2018 11:20 AM
โOct-09-2018 07:29 PM
riven1950 wrote:
SoundGuy...No I didn't. Don't want to steal this thread but can you explain about the element you are talkng about? Where is it? How would I turn it off? Showing my ignorance here. Thanks
โOct-09-2018 07:23 PM
riven1950 wrote:
I can tell you that my Dometic running on lp was killing a battery ( down to 12.0 volts ) every 24 hours when I had it parked in Jax Florida when we were evacuated from Florence. We were not staying in it and I pulled the fuse for the monitors so it was the only draw, at least that I could think of.
SoundGuy wrote:
Unless you also turned off or disconnected the fridge climate control heating element no wonder your batt was drawn down in just 24 hrs. :R
Did you? :@
BFL13 wrote:
The OP's Norcold doesn't even have one of those, so who cares? It will still want about 15AH a day as previously explained, based on actual measurements.
โOct-09-2018 07:13 PM
โOct-09-2018 06:53 PM
โOct-09-2018 06:41 PM
Did you? :@
โOct-09-2018 05:10 PM
โOct-09-2018 04:18 PM
โOct-09-2018 02:32 PM
Boon Docker wrote:Compared to what else you're expecting from your batteries, it's pretty small. If you have to plan for that kind of minuscule use, perhaps you need more batteries.
"Almost nothing" would depend on how big the battery bank is. If the battery bank is 600ah then even 15 amps is "next to nothing".
โOct-09-2018 02:23 PM
SoundGuy wrote:
Too funny - replies from "almost nothing" to 15 amps a day. :S
โOct-09-2018 02:06 PM
โOct-09-2018 12:53 PM
โOct-09-2018 12:42 PM
โOct-09-2018 11:44 AM
โOct-09-2018 11:42 AM
path1 wrote:
What does the average amount of 12 volt a fridge/freezer would use in 24 hour period. Norcold 621 in 60 or 70 degree weather? Maybe opening door 5 or 6 times?
