Quadcab's avatar
Quadcab
May 27, 2021
Fridge on the Fritz
Just plugged in the gas/electric fridge on our 2018 Crusader Lite 5th wheel and it will not turn on!? Gas is on, I double checked that. Electrical is working. The power button once pressed will show "green" light for about 3 seconds, then turns "red" and says to check the gas supply. Is there a simple fix that I am just not thinking of? Really feeling ignorant right now - like this should be obvious. Any help would be appreciated as my DW is worried this will affect our weekend camping plans.
  • In order:
    Verify 12+ VDC to the terminals accessible from the outside refrigerator compartment door. The PC board runs on 12 VDC as do the ignitor and gas valve.
    Have someone turn it on (set to gas) and tell us how far into the cycle you get:
    Hear clicking of ignitor
    Hear/feel gas valve openging
    Smell gas or see flame
    Flame stays lit
  • Since you are in SW Michigan, you are not far from Shipshewana, Indiana. Give Glenn Miller a call at National Refrigeration at 260-768-7059. You will not be disappointed. He will troubleshoot your fridge and fix it and he doesn't charge an arm and a leg. He's an Amish man, very honest, etc. He bought the business from Leon Hershberger and has relocated on SR120 north of Shipshewana about 1 1/4 miles. It's on a curve, new building. . . you can't miss it.
    Address is 6755 W SR 120, Shipshewana.
    He's troubleshooted mine a few weeks ago. Spent 45 minutes on it and didn't charge me. He couldn't fix it, but it wasn't the fridge. . . it was an electrical problem at the outlet. A friend in the campground (an electrical engineer) fixed it. That same friend had to run over to Shipshewana the next week and have Glenn change out the cooling unit in his fridge for $1100. Running great now, but his boiler had ruptured.
    He will fix you up for sure.
    Dale
  • How long has it been since you used the RV,
    Has It been sitting idle since covid 19 started
    The gas jet orfice is clogged, turn off the LP
    And blow the dust & spider webs out of the burner, THE flow tube, and the Orfice
  • Did you check the fuses on circuit board?
    Did you smell gas?
    Make and model of refer?
    Step back and take a deep breath for tonight!
  • Did not hear the ignitor, but have tried all day to get the fridge up & running without success. Should I unplug the electrical to let it reset? Thanks for your help BTW.
  • Do you hear the ignitor clicking?
    Did you try the refer a couple times to insure it has propane?
  • Yep, gas has good flow the the range. Still fridge will not turn on.
