llmax's avatar
llmax
Front panel delamination '99 terry 5th wheel
Bought a used Terry last autum. Noted a bubble in the lower front panel causing the panel to seperate from the lower outside corner trim. This spring the panel is almost completely seperated from the frame. How do I repair this? Is it moisture that has caused this - the roof seems in good shape. There doesnt seem to be moisture behind the loose panel.I Any advise? Thanks!
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
