Can someone tell me where the fuel pump relay is and where I can buy an owner's manual!Camper sat a while but it was driven up from Fl to Ga about 300 miles and had no problems! Than sat another 2 or 3 months and given to me! Can not bring to a shop will have to figure it out with help from you guys and gals! A friend of mind said to take fuel line loose from bottom of mechanical pump and try and start and if fuel comes out fuel pump is working but that still doesn't address the problem of is it the right size!
