dpglifestyle
Feb 19, 2019Explorer
With the factory fuel shutoff/kill switch you can unplug the kill switch portion and it will function as just a fuel shut off but you will not be able to just shut it off without adding a switch. Will work fine if you always want to run out all the fuel. For a couple of bucks you can add a momentary switch to the wire that needs to be unplug from the fuel shutoff
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
