Harleyhippie's avatar
Harleyhippie
Furnace AC problem
The last couple of days, the AC heat strip goes on when I turn on the furnace.
When the furnace heats up my 5th wheel, it shuts off but the AC will not shut off until I turn off the unit.
What's wrong?
  • LadyRVer is asking you about the fan setting on the thermostat.
    Both the furnace and AC fans may be controlled by a thermostat or two thermostats.
    But since you didn't give any model or back ground info, it's only wild guessing.
  • ➡ Did you miss the FTS "Announcement : READ BEFORE POSTING HERE"?
      Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum website,
      member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related questions.
      Instead, select the sub-forum which corresponds to the subject of your topic.
      Thank-you!
      Moved from FORUM TECHNICAL SUPPORT
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
