2112
Jul 28, 2021Explorer II
Furnace Air Flow
During our Texas freeze this winter I noticed the furnace had very little air flow and the ducts appear to have collapsed. The floor vents at the front and back have no air flow. They barely get warm after running for a while.
The service tech said it's typical for the ducts to 'bow' as they did and the only thing he can do is replace them. And then the new ducts will eventually do the same. The small amount of air flow is considered normal.
Is it typical for rigid heater ducts to bow in the center and pinch off the air flow?
How much air flow is considered normal?
Is there a minimum CFM measurement at the vent that defines 'normal'?
What's the best fix for this? The bedroom and basement gets zero heat.
Unfortunately, the furnace is buried in a cabinet under a counter and the underside is covered with coroplast. Nothing is easy to get to.
Any help on this is appreciated
