What the problem is is a laundry list.. What the SOLUTION list (During storage) is much shorter.
Option 1: Remove outside cover and if it's an Atwood furnace on top of the blower housing is what looks like a switch (it is a circuit breaker) Switch it OFF. Of course now the furnace is non-op till you turn it on.
Option 2: disconnect battery .. Physically lift the negative lead off the battery. (This also disables charging)
The laundry list OEM atwood board.
Bad T-Stat likely won't do it. same for T-stat wirings
Bad relay on control board
Bad other on control board
Short on control board wiring.
NOTE: There are two different patterns if lighting fails. Atwood shuts off fully and goes through the entire restart process.. Dinosaur board does NOT kill the blower.. SO if you have a dino board
Add the T-Stat and the T-Stat wires to the suspect list.
