Furnace Fire hazard
charlesdennis01
I want to make everyone aware of a potential fire hazard I encountered while I was trying to figured out why my furnace (AFMD35121_ _A) made by ATWOOD was smoking, almost killed my family and burned my RV to the ground. After taking the furnace out to find out why it was smoking I found a fault, the sheet metal used to protect the floor(plywood and linoleum)under the furnace is not protecting all the hot surfaces in contact with the floor causing the linoleum to dry up with time and subsequently cause a fire. If you are interested I have pictures and video that I can send. Please get the word out we could safe lives.
41 REPLIES 41
charlesdennis01
drsteve wrote:
Is the furnace exhaust pipe what caused this?
Yes the pipe cause that burn, after I took the furnace out I was able to see that the pipe was to close to the floor and the only way it could have caused the burn.
scary to know that it might be other furnaces out there that might have the same problem
drsteve
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
shastagary
you better check the high limit switch in that furnace. it looks like it is running to hot if it is doing that. no way should it get hot enough to do that. none of the 5 rv furnaces i have owned ever discolored the floor like that. the vinyl flooring should also be glued flat to the floor to dissipate more of the heat into the floor instead of the raw vinyl touching the furnace.
beemerphile1
Your vinyl (not linoleum) is definitely discolored. Mine is a different design but I am thinking that if the fan in yours is operating correctly, the heat will not be concentrated in one place.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
charlesdennis01
IAMICHABOD wrote:
IAMICHABOD
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
charlesdennis01
charlesdennis01
I will have to send you the pictures in a private message is not working sending them on the forum so give me a few minutes and lets talk about this so we can prevent future incidents
charlesdennis01
charlesdennis01
time2roll wrote:
Let's see those pictures....
charlesdennis01
charlesdennis01 wrote:
if you can give me a hand on how to post pictures here I will post all the pictures I have, with a detail explanation of what is that you are looking, some folks here are really critical of how things are being said, but is ok it takes all kinds to make this world go around.
This pictures is a close up of what happened, the pipe from the furnace was just to close to the linoleum and of course with time the flooring got dry from all the heat to the point of ignition.
The picture shows the pipe in question you can see that the pipe is just to close to the edge and the furnace should have been place with the spacers not directly on the linoleum or plywood.
This picture you can see the unsafe installation of the sheet metal, the linoleum and ultimate the furnace. Who ever did this was just lazy didn't even put enough aluminum tape to cover the edge and instead of putting the sheet metal over the linoleum or at least cutting the linoleum it was just left as is.
This picture is just a little further out of where the furnace goes in, again, according to the installation manual that comes wit the furnace it saids that the installation should be done from an exterior wall, if I'm wrong please illuminate my ignorance so I can learn more.
azrving
Open the link.
Click on select.
Pick photo from your computer and click open.
When the numbers and text appear in the box highlight it, copy it, paste it directly o this page.
Dont click any of the little icons above this box, just paste it directly.
2oldman
No, you can't post pics from your own computer.
azrving
Iirc my furnace sits on the linoleum. Are you sure you dont have flame issue with the burner and nothing is bypassed such as high limit switch?
