wrgrs50s
Feb 27, 2016Explorer
It sounds like there is an imbalance in the warm air around the thermostat. Is it possible that there is a heater vent blowing toward the area of the thermostat heating up that area faster than the rest of the trailer causing the thermostat to kick off early?
If so you might try setting a fan in that area to circulate the warmer air away, or partially closing off heater vents nearest the thermostat.
If you completely close off a vent it may cause the limit switch to overheat.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
