mikebarker87's avatar
mikebarker87
fuse blows on generator
I have an Onan Marquis 7000 model. it was running fine Now it has blown the fuse and i cannot figure out why. It has a 10A fuse and will blow immediately upon starting the generator. Thanks!
  • āš Did you miss FTS "Announcement : READ BEFORE POSTING HERE"?
      Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
      member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
      questions. Instead, select the Sub-Forum which corresponds to the subject of your topic.
      Thank-you!
      Moved from FORUM TECHNICAL SUPPORT
  • I unplugged all the plugs other than the main harness going to the starter switch and still blows. Not sure with one connects the fuel pump.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
