Neptune03dog's avatar
Neptune03dog
Gas tank gauge
I have a 03 HR Neptune Diesel coach and the gas gauge on dash stays on full. Some time it moves but now not so much. Can this be a ground issue and if so can I run a ground wire from dash gauge housing to frame to fix. Thanks
1 Reply
  • I believe most fuel gauges read full when grounded so I would think you may have a short somewhere. If you can reach the wire that connects to the gauge you can measure its resistance to ground see if it is shorted. There are usally two wires to the gauge. Voltage and a path to the sending unit. If you ground the wire to the sending unit it should read full, hence my belief that wire may be shorted.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
