Snowman9000
Nov 18, 2013Explorer
othertonka wrote:
It is working like it is designed to work. The first time it lit and there was still some air in the line and it went out. now it is designed to try and relight 2 or 3 times more before it locks out and displays the "failed to light" indicator, and you have to turn it off for a few seconds and then turn it back ON so it will retry until it lights or fails to light after 3 more tries. One thing you can do to help eliminate this problem is to light the kitchen stove and let it burn until it burns clean and all the air is expelled, then try and light the water heater. Works for me and as a bonus the refer will also light easier after you expel the air.
Hmmm. Well, it does this every morning. If there is air in the line every morning, that suggests a problem?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
