tuna_fisher's avatar
tuna_fisher
Generac Guradian Generator
I just got a toyhauler with a Generac and was wanting to adjust the valves, can someone tell me how you access the squirrel cage or the crank to turn the engine over to set TDC.? The trailer is a 2005 gen is 3600 watts 4700 series,Thanks.
  • tuna fisher I'm going to move this post from Toy Haulers to Tech Issues in hopes you get some additional advice.
  • jerseyjim wrote:
    FWIW, my 2001 GENERAC 5500 runs flawlessly (over 800 hours now)....I think I have hydraulic valves...in any case, it ain't broke so I'm not gonna fix it.
    Well it's broke so I'm fixing it. It had a broken rocker arm that the guy welded and it didn't hold. Got a new arm today in the mail. So I need to replace it asap and the valves will need to be adjusted, hence this post. Nice to hear your happy with your Generac as I've heard more negative than good, but that's what I got so I'm going with it. I got a Honda 2K but being to turn on and off from inside would be nice when it's cold and wet and I don't have to go outside and pull on a rope!!!
  • FWIW, my 2001 GENERAC 5500 runs flawlessly (over 800 hours now)....I think I have hydraulic valves...in any case, it ain't broke so I'm not gonna fix it.
  • Fulltimers wrote:
    The guy that did mine just bumped the starter to get into the ballpark.
    That's what Ive come up with, don't see any other way. And of course I'll pull the plug.
  • The guy that did mine just bumped the starter to get into the ballpark.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
