GlennLever's avatar
GlennLever
Generator A/C
My generator has failed (Onan 7.5)
I am purchasing one from a RV salvage yard.
It has a gray fitting below the control cable.
It is not on my unit, anyone know what it is for?
  • TEXAS wrote:
    That is where the AC wiring came out to the RV.
    I can just see that area while the generator is in the Motor Home. Mine does not have that.
    I am picking the Motor Home and the generator up in pieces after a failed attempt for Cummins to repair the unit.
    It will be interesting to see how my unit was hooked up.
    Thanks
  • Looks like flex conduit elbow,
    The output power was probably wired thru there
  • Looks like it provided a route for additional wiring from or to the generator.
    Perhaps for a second A/C unit or monitor system or was used on a boat instead of an RV and was wired differently....just guessing.
    I bought a used one from a military source, it had extra connections on it that mine didn't have. I just made sure all extra wires were removed or capped with wire nuts and tape before hooking it up to my RV.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
