โJan-25-2019 10:22 AM
โSep-01-2019 10:09 PM
Monster1 wrote:Consider a Panasonic inverter microwave. This unit actually reduces power to the megatron vs most microwaves just cycle the megatron at full power. I think the mid level power was measured as low as 600 watts IIRC. Of course if using 30 amp utility power you can run at full.
Seems like I need to buy a more energy efficient model that draws less power?
โSep-01-2019 09:57 PM
โFeb-02-2019 07:01 PM
BFL13 wrote:
My Briggs & Stratton portable gen has a red overload light that is supposed to come on and also the circuit breaker pops when it is overloaded.
Before that happens, when it is fully loaded and a bit, the red light flashes, but the gen keeps running the load. More load and the red light flashes faster. Reduce load and it flashes slower. Reduce load more and it goes out- just have the green light.
I have to run my gen with the red light flashing to run my 75 amp converter at 75 amps. Once amps taper to about 66 amps, the red light stops flashing and it is just the green lamp.
So---I suspect your gen is similar. If it does not pop its 120v circuit breaker, just leave it on to do the job. If you really do overload it, the CB will pop and that red light will come on like it means it.
โFeb-02-2019 06:21 PM
โFeb-02-2019 06:10 PM
โJan-31-2019 10:36 AM
โJan-31-2019 10:11 AM
Monster1 wrote:
Well anyway....... I just ended up buying a 2000w champion inverter generator from home depot. I couldn't pass up the deal. They were on sale for $299. Thanks again for all the replies.
โJan-31-2019 12:28 AM
โJan-29-2019 09:25 AM
ppine wrote:
For many people, it would appear that having an RV is supposed to be "just like home." I will never see the point of living that way on the road.
โJan-29-2019 09:05 AM
โJan-29-2019 05:47 AM
โJan-29-2019 05:42 AM
NormC56 wrote:
I enjoy "real" camping as much as anyone, heck, I used to "backpack" camp more than any other kind. I once sat out a summer monsoon in the Mohave Desert for 18 hours. I'm glad I didn't camp with my dog that trip. Storms are much more doable in my TC. All camping experiences are to be savored but you can reach a saturation point.
โJan-28-2019 08:34 PM
โJan-28-2019 06:50 PM
theoldwizard1 wrote:
For me, the decision of 1 vs 2 generators comes down to easy of moving them around. 2 small ones are definitely easier to handle !
