TEXAS
Nov 01, 2014Explorer
Take the door off. On the left side you will see a big black solenoid with two large terminals on it. One will have battery power all the time. That side is where the battery hooks up. It may have BATT printed on it. The other side supplies power to the starter. It should have power when you try to start it. If it does not you have a bad solenoid. If it does have power the starter is bad.
If you need a service manual. Go to smokstak Onan section post a full model and serial number. With an email address. You will receive a manual for free.
