MrWizard wrote:
typically the generator has (2) circuit breakers and one circuit breaker is wired to feed the A/C when there is NO shore power
normally there is a switch manual or automatic to prevent cross feed
it appears that is not working correctly
when you turned on the A/C the two p120v power sources got connected togther thru the a/c
Thank you! That sounds like exactly what happened. When we went to pick up the RV they had to "fix" an electrical issue. They said a ground and hot wire was crossed. Thinking maybe some other wires might have been crossed too.
