smkettner wrote:
All non-inverter generators produce a natural sine wave as part of the electromechanical conversion process. Although the wave can get distorted depending on voltage regulation and the type of load. The refrigerator (absorption or compressor) will work fine.
I'm not so sure that is correct. I once had a mission critical computer setup and I bought a contractor grade generator to take care of power outages. I didn't have time to test it out before a power outage came along. I hooked it up to my computers, which were supported by heavy duty UPS's. Well was I ever surprised when the UPS's wouldn't run off of the generator. I was told later that contractor grade generators don't have a clean sine wave, and UPS's need a clean sine wave to operate. Cheap generator output is more like a square wave.
I'm not an RV'r but I came to this forum because you guys and gals are the experts on generators.
I once suffered through a 9 day power outage in the middle of winter in Tulsa Oklahoma. Thus I learned through personal experience that my point of vulnerability was the refrigerator and furnace. I wasn't into computers at the time.
The purpose of my generator will be to provide emergency power for my home during power outages. I want to have enough juice to run my refrigerator, my gas powered furnace and my Ham Radio rig, which includes several computers and UPS's. (Ham Radio is a lot more sophisticated than it used to be). Most of that should run on the generator, but I may have to purify the sine wave for the computer stuff. I can install a small bank of batteries and a Charger/Inverter for that purpose. The Ham Radio gear runs from 12VDC so there will be several options there.
that's where THD applies to electrical power, not just audio. Here is a link to a very good article on THD.
http://powerupgenerator.com/total-harmonic-distortion-portable-generators/ Problem is that it's not always easy to get THD spec's for Portable Generators.
