Generator sizing issues?
95jersey
I have a 2017 Jayco 273 Toy Hauler (30 amp) with a single 13,500 BTU AC (according to their website). It has gas/electric water heater and fridge, micro, 2 (TV's), digital antenna, stereo and LED lights.
I occasionally dry camp and use my Harbor Freight Generator (4000/3200) to run the AC and assorted electronics (water pump, TV, stereo). I try to run the water heater and fridge on gas during these trips. Please no inverter recommendations, not interested in spending the money at this point.
I have run the generator right from the RV power cord as well as tried extension cords (10 guage) to run the generator further from the camper, with mixed success.
With the extension cord, the generator will overload occasionally and "pop the breaker" with the AC on. I have to go outside and reset the fuse. Sometimes this rarely happens and sometimes it happens frequently. I don't get why its so haphazard.
If I don't run an extension cord, it is more reliable, but will still occasionally "pop the breaker". I try to only run the minimal while running the AC such as (lights, water pump, maybe stereo/tv).
The manual says 13,500 BTU AC, but there was an optional 15,000 BTU available from the factory. I bought mine used so not sure which one it has. Also, it never "pops" at start up, it is usually when it has been running for a bit. So it seems the generator has enough power to get the AC going without issue. It is just a random breaker pop for no reason. It never pop's the camper fuse, just the generator.
So few questions...
1)why is the fuse popping more often with an extension cord? how long can you run an extension cord and what size to prevent this?
2)do I need to up size my generator to prevent further overloads? or do I have another issue with the RV?
Harbor Freight has a 4250/3500 and 6500/5500 in my budget. I would rather get the 4250/3500 as it is cheaper/smaller and more quiet, but I don't want to buy it and just have the same issue. They have a 6500/5500 for another $90, but it is another 40lbs heavier and 4db louder.
59 REPLIES 59
95jersey
Boomerweps wrote:
To give you an idea of your power usage to compare to available amperage, here's my measurements on my TT:
Fridge 328 watts 2.733 amps
Bathroom fan 40 watts 0.333 amps
Microwave 1230 watts 12.05 amps
AC 1446 watts 12.05 amps
D.C. Inverter at idle batteries charged 14watts 0.117 amps
Water heater 1245 watts 10.38 amps
Toaster 692 watts 5.77 amps
Electric space heater 1500 watts 12.5 amps
Electric griddle 1500 watts 12.5 amps
Single serve coffee maker 800 watts 6.67 amps
Add 'em up, read 'em and weep, but don't go over 30 amps!
Because of the above, I added an extra stand alone receptacle with its own power inlet on my TT. I also run an extension cord separate from the power source to a table under my awning for cooking gear and such. Also I shut off my air conditioner when using the microwave. Those two with the converter (amp draw depending on battery charge status) and fridge and anything else using electricity could put me over 30 amps. Heating elements are always a large draw. Water heater, space heater, cooking elements.
So I am not running nearly 1/2 of this. I never use micro, no space heater and no griddle. Just AC/water pump/TV or stereo. I should be well within spec both watt and amp. There is no way I am using 30 amp running the basics. Makes me think something else is wrong or the generator is beat.
time2roll
95jersey wrote:
Should I go to the 4250/3500 or just go up to the 6500/5500?
If spending money I would go with Honda 2200 and a Victron inverter that combines power.
pianotuna
Nomad III
Nomad III
95jersey,
I would move to the Harbor Freight Inverter generator.
Regards, Don
Boomerweps
3500 watts = 29.166 amps
4250 watts = 35.4166 amps
5500 wars = 45.833 amps
6500 watts = 54.166 amps
Electrical math using 120 volts. Watts divided by volts equals amps.
The larger number in the specs is very short term for motor starting.
The smaller one would work adequately at capacity, the larger one would easily power your TT 30 amp system and you could run other extension cords from it for other power uses. Me, I'd spend the extra of the larger unit and get a quieter generator with power similar to the smaller unit. Keep the generator as close to your RV as you can stand.
Something I didn't mention in my treatise above ๐Ÿ˜‰
Note that when the voltage drops, the amperage pull goes UP. For example, my AC drew 1446 watts at 120 volts pulls 12.05 amps after 40-45 wire run. Same AC after 195' wire length, 1446 watts, voltage dropped to 100.7, amp pull becomes 14.34.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
old_guy
I think you are missing the point here. after reading all the posts to answer your original post, you missed the fact you are going over your 30 amp needs and it won't make a darn bit difference if you get a bigger gen set, you still can't go over the 30 amps, period plain and simple
Boomerweps
95jersey
MrWizard
Moderator
Moderator
Water pump lights etc...use battery power, your generator is powering the converter, let it charge the batteries before you turn on the A/C
Using the extension cord will increase voltage drop and breaker trips
Having other items using power
Letting the A/C cycle the compressor will increase the chances of breaker trips
As the A/C compressor warms up, and ambient temp warms up, the start surge for the compressor takes more amps
This is the most likely problem, having the A/C on a setting where it cycles the compressor
In a mild day it might cycle without overload
On a day that gets hot, you reach a critical point where the restart cycle load is too much for the generator
I can explain it to you.
1997 F53 Bounder 36s
time2roll
If the battery is low on charge the converter can draw around 1000 watts. Microwave will pull 1500. Fridge 350. Water heater 1400. Coffee 800 to 1750. Electric cooking will also draw 400 to 1000 watts each appliance. Some of these run on a thermostat so it could seem random when the overload hits.
So you may need to give your converter an hour to charge the battery before you crank on the A/C. Otherwise watch what else is plugged in.
Also if you are at 4000+ feet altitude your generator will be derated some due to the thin air.
I doubt the #10 extension is causing any meaningful issues.
George3037
Just remember your TT only has a 30A circuit. Usually the factory 30A cord is 25-30' long. If you are running the A/C, Microwave, Coffee pot, Toaster, and your distribution center is probably charging the house battery at the same time. The combination of using more than one of these devices at the same time can easily trip a 30A breaker either in the TT or on the generator. Adding an extension cord only adds to the load and makes it worse.
Your generator is more than capable of running your TT. The problem is you are maxing out the 30A circuit from time to time. Going to a larger generator will not help as you are still limited by the 30A circuit in the TT.
You need to buy or borrow a DC amp meter to measure the amp draw of your TT. My guess is you are maxing out at 30 amps or more causing the breakers to trip.
Also, if you take off the cover when you clean your A/C filter there should be a label inside that will say whether you have a 13.5 or 15K A/C unit.
Boomerweps
Www.calculator.net voltage drop calculator
Voltage will drop over a wire's length and gage (AWG). The amount of drop depends on the amperage load.
I used a Kil-a-Watt meter (~$25 at Harbor Freight) that you plug into your outlets or inlets. It's made for a standard house 15 amp Edison plug. So I run an extension cable from my source to the meter, then into the TT using a 15 amp to 30 amp adapter. Then I turned on various items one at a time to measure the wattage/amps used and how much voltage loss I had. I also metered using multiple items turned on at the same time. So I now have a good idea of what I can run together, given the length of extension cords I used, all 12ga.
I've not run any 30 amp or 10 AWG extension cables while measuring.
The amount of voltage drop can be significant based on AWG & cable length. I actually ran 195 feet of 12AWG from my circuit breaker box to my TT at one spot on my property. My voltage read 112VAC at the TT inlet with just the 12VDC converter powered. Add fridge, 109.7VAC. Cut fridge, turn on Air Conditioner, 100.7VAC. I no longer consider parking the TT there ๐Ÿ˜‰
On the concrete pad out my back door, very little drop with 45-50' of wire.
At my current storage site, about 85-90 cable feet from the CB box, 107.7VAC with the AC on but within operating specs. I did add a Progressive Industries EMS install unit so I don't need the Kil-a-Watt to measure amperage use and voltage on the whole TT. But it would shut down all power coming in if I was to use that 190' spot due to low voltage.
Starting amp draw on motors increases by 50% or more when starting.
95jersey
I never run micro with AC on. Maybe the AC/TV/Water pump/refrig/Lights and some iPhones charging. It may run for 3 hours fine and with no load changes, and then it just pops the breaker. I agree the generator is cheap. Also, yes the power cord was not a 30 amp, so I need to get the appropriate cord. But that does not account for why a 3500 watt generator is popping the breaker randomly.
I have no issue upping the size, but will the 4370/3500 be enough? That is only 300 more watts running than the one I have. The 6500/5500 is only $89 more, but it weights another 50lbs and is probably a little louder.
Is there anyway to test the generator? Do dealer have a watt meter to measure my actual usage?
nineoaks2004
You stated a 10 GA cord, but you failed to state how long the cord is, you will have a voltage drop according to length. I can run anything in my TT with no problem but I do not use an extension cord. Are you using a microwave at the same time the breaker trips? This can /will cause a problem. Also could be a weak breaker at the Gen.
By the time you learn the rules of life
You're to old to play the game
RoyF
The extension cord I would use is of the same gauge as your Rv's 30-amp cord. That's not the "ordinary" extension cord which is good for only 15 or 20 amps and is not rated for 30 amps.
2oldman
cheap generators (a good assumption since it's HF) are likely not to live up to their ratings, or surge capabilities.
