Monaramblee's avatar
Monaramblee
Generator stalls
It starts up beautifully, runs for a few minutes then stalls. After it stalls it will restart beautifully and run for a few more minutes then stall. I have adjusted the oil and antifreeze levels and unplugged the remote switch to rule out the remote switch.
Was thinking the fuel filter might be clogged but a little voice in my brain says that if this was the case it might not start so easily.( but the fuel filter might be the issue) Oh after it stalls it flashes once repeatedly and after i touch the off position it flashes 3 times incrementally. It stalls with or without a load.
Its a onan diesel...
Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
