Jay_Pat
Oct 11, 2013Explorer
Trackrig wrote:
The cloth won't help your vibration problem, you need to put some rubber between the generator and the frame - and then don't over tighten it. The Onan people should be able to sell you some sort of rubber vibration dampners from one of their generators. Or, look in the yellow pages if you still get them for a rubber supply place that sells hoses, conveyor belting, sheet rubber, etc. They should be able to give you some scrap belting (3/8" to 1/2" thick) that will do the same thing.
Bill
I'll check with Onan.
Thinking more about this, there is a thick rubber mud flap material for the big trucks that could work. Thick and not too hard.
Thanks!
Pat
