I turned off the generator while both AC were running, now the Generator runs crappy, like it has no guts, even if I remove the plug that feeds from the Generator to the RV. PS The AC's still work fin...
It's a bad idea to shut down an engine while running at full load. I would check the compression to see if you warped a valve or caused other internal damage. While this isn't a common problem, troubleshooting starts with checking the patients vital signs.
