Sandia_Man
Mar 13, 2018Explorer II
We have had our Champion 3100 remote start inverter genny for 3 years and had no issues running it at 5600' elevation here at home with the stock carb jet. Read the manual and it declared we needed a high altitude jet as you indicated above, called Champion and they readily sent one out. Installed it and found that after running it with the new jet I could tell no difference in performance or power production.
We predominately camp at high elevations so I just left it in there for the time being, we ran it with the stock jet for nearly a year, even above 8K' elevation and it performed well. I wouldn't be too worried running the stock jet for occasional use at higher elevations if that scenario works better for you. I didn't find replacing carb jet overly taxing as I set it on a work table making it easy to maneuver, after the first time the process is not too bad.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
