Our Dometic refrigerator is popping GFCI breakers when it runs on 120 volts. I pulled the heating element and it has three leads, one of which is the ground. Connecting these directly to a GFCI circ...
A GFCI will trip if it detects as little as 5 milliamperes difference between the current flow thru the hot pin and the flow thru the neutral pin in the outlet. That small current can leak thru a high resistance ground fault.
Could also be a GFCI going bad.
