SnugHarbor's avatar
SnugHarbor
GFCI receptacle 03 Scepter
Can't find the GFCI receptacle in our 2003 36PST Scepter to reset. The wiring diagram I have is labelled 38-40 ft PBDD Camelot / Scepter, a different model; the wiring diagram indicates the GFCI is located in the bay. Notes on the same drawing state Bath GFCI. Have looked in the bays and the bath, no receptacle. In case they hid it, even removed dresser drawers, emptied kitchen and bathroom cabinets, still no receptacle.
Anyone know where they hid this thing? Thanks.
  • It is possible that the prior owner replaced with a common circuit breaker. I just replaced one and it was $69. I checked the web and that was a fair price.
  • wa8yxm's avatar
    wa8yxm
    GFCI's are usually recepticals but can be circuit breakers as well..
    One trick if it is tripped is to go in under twilight conditions, Look for the tattle tale light... Hope it is the kind that comes on with GFCI tripped.
    Also, if not the original owner. A prior owner may have done something dangerous.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
