- wa8yxmExplorer IIIShort answer: That means the rod is working as designed.
- whiteeye42ExplorerNormal just clean the rod and the water heater and re-install the rod good to go
- Old-BiscuitExplorer IIIAs Aluminum anode rods corrode they can produce an aluminum oxide deposit.
The aluminum oxide forms a virtually odorless "gel" substance that can vary in texture from a firm somewhat sticky curd to a thick running slurry.
The gel can be either milky or clear.
Typical with higher PH water source.
Flush and rinse WH
Change to Magnesium Rod........but they can dissolve quicker so check routinely to get an idea of life span.
Also they can react with high sulfur content water source and produce Hydrogen Sulfide Gas ----Rotten Egg Smell. - Dakota98ExplorerSeems to me there was a posting very similar to yours a couple months ago. Might do a search & see if you can find it.
Having RV issues? Connect with others who have been in your shoes.24,214 PostsLatest Activity: Mar 14, 2025
