hyfyve
Jan 19, 2015Explorer
wolfe10 wrote:
Two questions:
I don't understand the 120 VAC OUT from the converter to A/C, refrig, water heater
Also, what you label a "switch" could be a switch, or if the inverter has a pass through feature, a sub-panel (better).
Wolfe, I am just assuming if I didn't have shore power and had to run on the inverter then if I have the high wattage devices running through the switch the inverter wouldn't handle it, by leaving those items running only when shore power is connected then I should be OK, but please if I am wrong someone let me know, just want to make sure I do this properly.
BFL13 wrote:
Change "converter" to "power centre" The converter is just the part of the power centre that makes 120v into 12v. It has no 120v output.
Fixed thanks
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
