โApr-30-2020 06:16 AM
โMay-01-2020 02:58 PM
โMay-01-2020 02:54 PM
enblethen wrote:And as is so typical, the first response is yet another incorrect one, by a moderator/staff member no less. Trying to convince people that GFCIs do zero-current neutral-ground detection is an uphill climb.
This is from Mike Holt forum
โMay-01-2020 11:04 AM
Bud
USAF Retired
Pace Arrow
โMay-01-2020 09:35 AM
โMay-01-2020 09:34 AM
DrewE wrote:What's really frustrating is it's still difficult to find a "How GFCIs work" article on the Internet that includes the grounded neutral detection. If you're trying to debate somebody who doesn't think it's true, they can find at least 10 incorrect articles that omit the neutral detection for every one you find that's correct.
Grounded neutral detection has been part of the UL specification for GFCIs since at least the 1993 edition of the spec, possibly longer. It is not a new thing at all.
โMay-01-2020 07:16 AM
โMay-01-2020 05:52 AM
dougrainer wrote:
This is from FLUKE corporation, Electronics tester maker. Doug
A GFCI uses a current transformer to detect the difference between the line current supplied to the load and the neutral current returning from the load. Ideally, this difference should be zero because both currents cancel. If there is a current differential, it becomes the input to a comparator within the GFCI, which changes states when the differential is around 6 mA. When the comparator changes states, it triggers a silicon-controlled rectifier, which disconnects the power from the output of the GFCI.
โMay-01-2020 04:22 AM
โApr-30-2020 04:55 PM
vermilye wrote:
Part of the confusion of what capability is built into a GFCI is because the original design of a GFCI only detected the difference between the hot & neutral, but newer ones have a circuit added that detects ground/neutral faults. I don't remember the year this addition was made; I have a request at Mike Holt's forum that may provide an answer. If I get an answer, I'll post the information here.
โApr-30-2020 02:22 PM
โApr-30-2020 01:53 PM
โApr-30-2020 12:35 PM
dougrainer wrote:Bobbo wrote:
Yep. That is THE classic cause of a ground fault. Turning on the electric element in the water heater without water in the tank almost instantly ruins the heating element. The heating element then makes contact with ground. That NEUTRAL/GROUND contact trips the GFCI every time. Your solution is to replace the heating element in the water heater. The breaker being on or off doesn't matter. The short is between NEUTRAL and GROUND, and neither one is disconnected by a breaker.
Sorry, When a Water Heater Element "Blows", there is NO CONTAC to a ground source. The Blown part looks like a small weld slag on the element. What DOES cause a GFCI to trip is the IMBALANCE of current between the Neutral and HOT. So, When the Current tries to flow thru the Heat element, the blown element causes an imbalance, of current and the GFCI sees this as a Short to Ground. I have found very few 120 Water Heaters connected to a GFCI, but it makes sense to have it connected to a GFCI. Doug
โApr-30-2020 11:52 AM
Bud
USAF Retired
Pace Arrow
โApr-30-2020 11:16 AM
