cmt511
Apr 30, 2020Explorer
Heat element & shore gfci
Hello
Shore gfci questions here. Like many others I now have an issue when plugged into shore power gfci at home (I've used this same outlet for 5+ yrs and tried another circuit to confirm this outlet was good) I've gone through the process of elimination with the breakers. The Gen breaker is defiantly the issue. Trips the shore gfci every time. No other breaker trips it. I did accidentally turn the water heater breaker on with no water in the tank and the electric switch on. Wondering if the element is now bad and causing this even with the breaker and switch off? Is there still current trying to run through the element and shorting? Not sure if they are related in anyway. The water heater and gen share a dbl pole breaker. The fridge works fine. Everything works when plugged into non gfci. Any help would be appreciated! Thanks
