W8-4-me
Jan 18, 2024Explorer
Your battery shown appears to be a 6volt battery is your second battery the same? Your rv should run on 12volts so you need to run your batteries in series like in the diagram which will ADD the voltages. (Don’t pay attention to ah in diagram. You may need to follow some of your wires to determine where they are attached.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
