Jun-24-2013 10:59 AM
Jun-26-2013 08:21 AM
wilco wrote:
My leak was the valve. $50 bucks from CW for an incredibly "modest" looking plastic replacement. Had to remove the whole toilet to get adequate access.
One of those "character-building" RV days. Start by stepping into a puddle of ice-cold water at 6AM. Spend the morning looking for what ends up being an incredibly expensive (for what it is) plastic part. Spend the afternoon disassembling the one system in the RV you really never wanted to deal with! But, end the day with a satisfying flush!
Jun-26-2013 04:10 AM
Jun-25-2013 08:27 PM
Jun-25-2013 07:17 AM
Chuck&Gail wrote:
One point just in case. I assume you are using a pressure regulator between CG water supply and input hose, right?
Jun-25-2013 02:47 AM
Jun-24-2013 09:39 PM
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories
I can't be lost because I don't care where this lovely road is going
Jun-24-2013 02:17 PM
Beverley&Ken wrote:
Our Thetford Bravura model is held to the floor with 2 nuts/bolts, one each side at the base of the toilet. Ours are covered by plastic caps, some models may have a snap on cover to hide them.
Just undo the bolts and lift the toilet and turn sideways to see the valve mechanism at the back of the toilet, the plastic water lines should be flexible enough. Ours was leaking from a split/crack in the water valve (about $50 at our local RV store. Also replace the wax or foam seal ($2-3 part) were the toilet seats to the pipe going to the black tank. Almost all toilets, stick house or RV are held to the floor with the two bolts held to a toilet flange screwed to floor and sealed to plumbing pipe.
Beverley and Ken
Jun-24-2013 12:09 PM
Jun-24-2013 11:49 AM
Jun-24-2013 11:28 AM
