โNov-27-2018 05:22 PM
โNov-28-2018 05:31 PM
beemerphile1 wrote:
Thanks all. For the most part you have confirmed what I thought, no ground from the panel frames.
I also did not ground the controller.
I did ground my 2,000w inverter.
โNov-28-2018 05:30 PM
โNov-28-2018 05:13 PM
โNov-28-2018 04:21 PM
beemerphile1 wrote:
A couple more weeks and we can head south.
โNov-28-2018 11:25 AM
โNov-28-2018 09:43 AM
BFL13 wrote:
The panel ground is from a lug on the frame, not with the "pos" and "neg" wires of the pigtail/junction box to controller.
โNov-28-2018 08:38 AM
bpounds wrote:bpounds wrote:beemerphile1 wrote:
On a serious note - do you ground your solar panels? I noticed they have an attachment for a ground wire on the frame but I didn't see the point.
Ground mounted, yes. RV, no.
To clarify, by ground mounted, I meant a sticks and bricks installation. I did not mean an RV with portable or even roof mounted panels. I can see that I should have been more clear on that.
I fail to see the point in grounding the panels in an RV, which is sitting on rubber tires and wood or plastic blocks, with panels mounted to a wooden roof covered with rubber or fiberglass. On the other hand, it can't hurt, and a piece of wire is cheap enough.
I noted when I was shopping that the sheathed cables specifically intended for a solar system (#10 red and black wires in an outdoor rated sheath) did not come with a ground lead. Grounding would require a 3rd loose cable, and none of the system installations I reviewed had that. The fact that the MC4 connectors did not provide a ground pin also informed my decision.
โNov-28-2018 08:10 AM
beemerphile1 wrote:No, and I don't ground my generators either.
do you ground your solar panels? .
โNov-28-2018 08:07 AM
โNov-28-2018 07:10 AM
โNov-28-2018 06:52 AM
โNov-28-2018 03:55 AM
โNov-27-2018 06:03 PM
โNov-27-2018 05:52 PM
