- MrWizardModeratorthe 458 is a Xantrex product
the Freedom 10 or Freedom 20 is a 'Heart Interface' product
the company that Xantrex Bought
these products do not Sync with input line power
there are inverters from Victron and Magnum, that will do that
to the op
unplug from shore power
hit the battery disconnect
unplug the remote panel plug at the 458
disconnect the batteries for 5 minutes
reconnect everything reverse order
and try your inverter again
sometimes they 'REQUIRE' a reset procedure be performed - jplante4Explorer II
2oldman wrote:
I do know the inverter will not work when connected to shore, but my experience with Xantrex products tells me you can 'activate' it at that time, but it will not actually invert until shore is absent and there's a sufficient load to invert for.
I don't know how the inverter would sync with the shore power if this were possible. I was going to try this on my Xantrex, but I chicken out. I had visions of the Xantrex shooting out the side of the motor home and wiping out the DE's car, then catching fire. - 2oldmanExplorer IIEveryone says you're welcome.
- Discovery8ExplorerThanks everyone. It was the wiring. It's working now.
All I can say at this point is to make sure all your wiring is correct. You do have batteries hooked up, right?
That's what I am checking now. - 2oldmanExplorer III do know the inverter will not work when connected to shore, but my experience with Xantrex products tells me you can 'activate' it at that time, but it will not actually invert until shore is absent and there's a sufficient load to invert for.
All I can say at this point is to make sure all your wiring is correct. You do have batteries hooked up, right? - Discovery8ExplorerNo, nothing about the inverter not powering on. In the trouble shooting section I found my status which is inverter light off, charger light steady green and it gives me a description and says to push the inverter button. I've tried calling the phone number on the manual but they are out of business.
- 2oldmanExplorer III guess there's nothing in the manual about this?
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
