bondj007
May 03, 2016Explorer
Sigh - air bubbles seem to be a red herring - Old-Biscuit you got me thinking so I removed the strainer completely - no more air bubbles. Thank you. Problem is the 5 sec pressurization problem still persists. HW by pass on, pump shuts off immediately when closing tap; by pass off - takes 5 secs to pressurize. Water hammer on cold inlet pipe to hw tank. On the good side - something clearly not sealing properly on the filter so will replace.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
