bondj007
May 03, 2016Explorer
OEM was shurflo 2088-422-144 - 30 psi inlet, 45 shut off vs 55 for the 4008 as you mention. I've done a little trial and error on setting the pressure switch so not sure where it sits at the moment. What would be the consequence of going to a higher rated pump?
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
