speediq99
Mar 24, 2022Explorer II
Thank you Dan.
That is the route we are taking to start.
If I find myself annoyed by having to pull over to open the manual valve, I may install the solenoid.
MC
MC
dapperdan wrote:
MC, I’m not sure what’s changed since my ‘15 RAM but my truck didn’t come with a fuel cap either, just a “flipper” style closure. When I first installed the RDS in my ‘06 RAM I DID have a fuel cap. My installation into the ‘15 was similar to the ‘06. Under the truck up in the fender I cut the metal filler tube, spliced in the “T” with the rubber boots included in the RDS kit. Supposedly there’s a check valve setup to prevent over flow. I’ve never had an issue with fuel spills!
I run the truck tank below half of more then flip the valve on the RDS tank and let the fuel from the RDS gravity flow into the truck tank. It looks “weird” to be running down the road and have the fuel gauge start climbing! LOL The install is fairly easy and having the extra fuel capacity is great!!
Dan
Having RV issues? Connect with others who have been in your shoes.24,214 PostsLatest Activity: Mar 15, 2025
