railtrailers
Sep 01, 2018Explorer
I purchased an AIMS PWRIG150012120S a couples of years ago. It was specifically selected as it was advertised as "bondable". After a long delay, I finally got around to that project after the window to return it had expired. Before installing it, I chose to run some electrical tests to confirm the operation. The AC voltage line to neutral was a solid 120 volts and it handled an electric space heater quite well. However, I also measured the voltages from line to ground and neutral to ground and both read equal (but reduced) voltages! I suspect that they push the positive going half AC cycle out one lead and the negative going out half AC cycle out the other lead rather that a true full sine wave cycle out the line lead. The only way that I would consider bonding the neutral to the ground with this inverter would be to run the power through an isolation transformer which could cost nearly as much as the inverter itself. Another project on the shelf to get back to "someday".
