Saddlebum13's avatar
Saddlebum13
high pressure propane regulator
I have Gas Flo Model GR-630 regulator that started leaking. I have searched about everywhere to find one. I called the nearest Keystone RV service center and they don't have one and said they can't get one.
Does anyone know where I can get one?
  • Update: My Cavagna 914 30psi regulator that I used as a replacement died just like the original red one. Bought whatever was available on Amazon, which is the red one again. Guess I'll just keep a spare.
  • Update...
    I purchased a Cavagna model 914 30 psi single-stage high pressure regulator from Amazon. Looks like it solved my problem.
    Thanks for the help!!
  • Here's the specs on that regulator. Maybe you can find a substitute.
    30psi non-adjustable Propane Regulator LP Gas.
    GAS-FLO GR-630
    IN: 1/4" Female NPT
    OUT: 1/4" Female NPT
    BTU 2,500,000
    Richard
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
