pianotuna's avatar
pianotuna
Nomad III
Oct 23, 2015
high rate charging on generator
Hi all,
The batteries:
556 amp-hours of surplus acid AGM batteries 12 volt jars 105 lbs each. They are wired as two banks with balanced wiring.
The depth of discharge:
12.1 volts under 425 watts of load plus normal RV overhead applied for 4 hours. During the day the fridge (325 watts) was run for 5 hours and the RV was driven at highway speeds for 3 hours. On the last hour of driving charging was initially 50 amps but that soon tapered to 25 amps. The solar contribution was about 5 amps.
The generator:
Yamaha Sieb 2800 Va (23 amps of output @120 volts AC)
The inverter/charger:
Magnum 3000 hybrid.
What happened:
I deliberately took the battery bank down farther than I normally would. I turned on the generator after setting the Magnum to draw no more than 23 amps.
Within one minute the Magnum remote reported "fet over load". Remote was showing 127 amps of charging at 12.9 volts DC just before the over load shut down.
I reset the Magnum by removing all power sources. I "dialed down" the possible input to 15 amps from 23. This still caused the Magnum to display 125 amps of charging. I finally dialed it down to just 13 amps to prevent over load on the fets. At that level charging was 90 amps @ 12.5 volts.
I've been charging for 45 minutes at 90 (+) amps and the voltage had risen to 13.8.
I 'opened up' the input to 23 amps and after 15 minutes it is now charging at 14.3 @ 98 amps. The remote is saying absorb charging.
15 minutes later and the remote says 14.3 at 80 amps.
1.5 hours and charging is 14.4 @ 27 amps.
During this time frame I did also run the microwave and three oil filled heaters (400 watts each).
The generator was running with the eco switch on and at the 45 minute point started throttling back as the load shifted.
Next time my voltage is so low I'll dial the Magnum down to 13 amps to start out.
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 14, 2025
