BFL13
Sep 07, 2019Explorer II
BFL13 wrote:
There is a duplex 15a receptacle and a 30a twist type. You used your bonded plug in one of the two 15a? but the 30a was occupied by whatever.
Ok, in a recent thread, it came out that there is something going on between the 15 and the 30 so they are not all the same wiring, so what you got was as though before you do all that needed work with the wiring in behind there, so when you bond a 15, it does not screw up the 30 --or whatever that was all about. ( It was complicated!)
Bobbo remembered what it was in the above mish-mash. The 15 and 30 with reversed polarities. They had to take the panel apart and rewire the 30 same way as the 15. ISTR it wasn't a Honda in that case, but whatever, it could be that same thing.
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
